Why so many fuelpak for sale?
This is very time appropriate. I'm planning on putting in a set of Wood TW6-6 cams in my 07 RG this spring. I have a FuelPak..(maybe I made the wrong choice a couple of years ago..). Anyways, the bike has been working fine, but I wanted a bit more "oommph";...Yesterday I emailed V&H and told them of my upcoming addition. They sent me the code for the new map. If the map is accurate, I don't see the big negative issue, for the average rider. I guess we'll see when the cams go in. Personally, I would hate to throw the FP away, if I don't have too, just for the sake of having the latest and greatest. Has any FP owner installed cams? What was your experience ?? Thanks
They have maps for the an-26H and the SE 211 cams for the 96 ci
I to had the fuelpak for 30,000 miles and changed cams. They gave me a map that worked but the bike ran hot. I installed the PCV w/AT from fuelmoto. My mileage went up 4 mpg and the bike ran a lot cooler with better throttle response.
If V&H would make it so 1 could tune it dyno or other methods I think they would sell more. The word is out about the restrictions with it.
Nothing wrong with it if you stay with factory cams.
If you go to 103 ci with se255 cams they have a map
just my thoughts
dd
just my thoughts
dd
A tune is a key componet to have on any bike.Think of it as a base building block to work off of.The key to it all is that a well tuned Tuner mapping both cylinders will balance the air fuel ratio properly,meaning your bike won't hot (too lean) or popping (too rich).A proper shop for the Power Commander would be to tune it on a dyno that has a Link center.That way it's tuned to perfection.
Fuelers are a waste of money,in my opinion.Tuners are the way to go.When doing ANY head work,make sure you know what kind of power your looking for.Low to mid end,lots of torque,or mid to high end.Choose cams properly and then have your heads done per cam specs.Harley's pick your cam and pick there SE ported heads don't make that much power for the price.The only thing I got that says SE is my push rods.I point it out to everyone in case they miss it.LOL
