Backrest Help.. Too Far Forward... Modification?
Old 01-30-2010, 04:17 PM
jasnusc's Avatar
jasnusc
jasnusc is offline
Default Backrest Help.. Too Far Forward... Modification?
I bought a backrest for my 09 SG and istalled it today. I installed the bracket as far back as it would go still allowing me to insert it through the slot in the seat.
I thought I read previous posts about people doing modifications but I couldnt find anything using the search.
I thought of heating up the 2 round bars and putting a slight bend in them to give me a little room.
Any other suggestions or advice would be helpful!
Old 01-30-2010, 04:44 PM
e6fmf's Avatar
e6fmf
e6fmf is offline
Lower your footboards
Old 01-30-2010, 04:54 PM
ezryder62881's Avatar
ezryder62881
ezryder62881 is offline
I complained of mine on my 08 Ultra, not so much too far forwards as wrong angle. Seems like it needs to be reclined at the top just a bit. I think 1/4-1/2 inch of reclining would make a huge difference. Never have made time to bend it yet, but still thinkin about it. Guess I kinda got used to it the way it is.
Old 01-30-2010, 06:58 PM
jasnusc's Avatar
jasnusc
jasnusc is offline
I was really hoping someone would have modified one by now and would be able to share!
I bit the bullet and installed it to help out my back even though I think its ugly.
I know they make the adjustable one but I couldnt afford that right now.
Im a bigger guy, 6'2" 240lb and it pushes me forward into the tank.
I think heating it and bending it would help give me that extra 1" im looking for?
Old 01-30-2010, 07:09 PM
kipd's Avatar
kipd
kipd is offline
On my 09 ultra I added a few spacers to the front bolts of the backrest support, it helped a bit leaning it in more of a reclining position. Its not much, but it seems to be adjusted correctly for me now.
Old 01-30-2010, 07:33 PM
nvsteve's Avatar
nvsteve
nvsteve is offline
That's the biggest complaint about the HD backrest. You need to bend it or,
get the Mustang. Way better.
Old 01-30-2010, 07:46 PM
2of2's Avatar
2of2
2of2 is offline
Try it on the lowest set of holes in the bracket. If mine is up one set higher then I am cramped. When I lower it I am comfortable. Makes a big difference for me.
Old 01-30-2010, 07:50 PM
stro1965's Avatar
stro1965
stro1965 is offline
I bent mine but only because it never occurred to me to shim up the forward edge of the bracket. I'd try that first.
Old 01-30-2010, 08:13 PM
shagnasty's Avatar
shagnasty
shagnasty is offline
I put mine in a vice and heated the two rods and just pulled back until I felt it move a little bit. Let it cool and it was perfect. Might have to do it a couple times to get it to suit you. I got lucky. BTW, remove the spring between the rods before you heat them. It will ruin the spring if you leave it in......don't ask
Old 01-30-2010, 09:21 PM
jasnusc's Avatar
jasnusc
jasnusc is offline
Cool... Thanks guys.
Ill try to shim it first if not I will get the torch out.
Quick Reply: Backrest Help.. Too Far Forward... Modification?
