Electrical Head Scratcher
Ok, I have the outer fairing off and took the inner cap off off of this '09 EGS. I installed the Cruise Control on the handle bar and the Cruise switch on the inner cap. When I put it back together I've got no power to the Aux switch - next to the new Cruise switch and no power to the cigarette lighter (tested with a multimeter). [All was fine previously and it's not like I've unplugged a bunch of wires or anything.]
There is power to the Cruise switch as the light on the switch comes on. The one on the Aux switch doesn't. And as I said, no power to the cigarette lighter. Fuses look good.
Took the inner cap off again and all looks good at the 105B connector. Can't test power to it as the fork is locked with the ignition switch removed from the bike.
Any ideas?
Any ideas?
Do you have a Service Manual? I ask because 99% of the time, the problem is a pinched wire in the switch housing you installed and by identifying wire colors associated with the lost function, you can pinpoint the problem. Also, a blown fuse may be difficult to identify without bright light and good eye sight; I know from personal experience 'cause I've though a fuse was good when, upon closer inspection it wasn't.
Also, I'd double-check for an incorrectly wired cruise on/off switch in the fairing cap.
Hope you get the problem resolved soon.
Carl
Carl
Just got down working the Predator's - Thrasher's game so I'll tackle it in the morning. I'll let you know what I find.
