Lubricate cables
Can't have looked too far. Best approach I've seen is detach clutch cable from lever (loosen cable first of course). Cut the corner out of a ziploc bag. put cable thru corner of bag. Secure bag around corner with rubber band (or zip tie). Put oil in bag (must would say use same oil as transmission oil). Allow oil to flow down cable.
Throttle cable is another story - Many recommendations here for DriSlide.
http://www.motionpro.com/motorcycle/partno/15-0001/
I have an attachment that goes on the cable and you spray lube in it and it 'forces' the lube through the cable. You would need to do the clutch cable from the top and from the adjuster towards the clutch housing...
Got my adapter and cable lube(looks like a can of wd-40) from Dennis Kirk... here
The throttle cables are a bitch and hate doing that job. Those little ferrules are a PITA. The last time for that ordeal I used a dental syringe (plastic), and I think you can get these from a pharmacy. Or, you can browbeat your dentist like I did. The opening of these syringes is just barely large enough for oil to flow (slowly), yet small enough to fit inside the cable housing. My HD tech suggested injecting the oil at the adjuster. Loosen it all the way and expose the housing at the bottom of the adjuster. I'll be trying that method with the syringe next time.
I made one for the clutch cable using a short piece of clear plastic hose that barely fits over the eye of the cable. A small hose clamp seals it around the cable housing. i put a small amount of oil in the hose and use my air gun at low pressure to force the lube down the cable. Takes less time than writing this post. Got a cable luber (just like the one from Motion Pro) for the throttle cables.
I've found this stuff to be awesome!...loosen your cable adjustment, take the lever assy lose from the handle bars.....drip 20-30 drops into the cable entrance using the syringe that comes with the lube.....re-assemble, adjust your cable and bada boom, bada bing...you're done. I've been using this for 2 years now and I love it......much better than any dry lube I've seen.
http://www.amazon.com/gp/product/B00...53S2WVN87Z5X3E
You guys with the baggy and rubberband, great idea but the braided lines can get stained that way. Black lines, no problem. But the Inox is still faster and easier.
Dry slide is good, but my applicator tip got clogged so many times that I threw the chit away.
Inox,.... the best and easiest I have found. Even smells good. LOL
I usually do my lube every 3,000-4,000 miles, when I service my bike. I change all my fluids except my tranny and clean my air filter (K&N). In my tranny, I use Amsoil Severe Gear....good for 50,000 miles. I love that stuff too.
