2010 2 into 1 exhaust
Thanks for any more info you can offer!
Ok, I see that, does it break up when you bust it out? Come out in pieces? Or is it "Glued" to the pipe on the edges sort of? It would seem if you kept breaking it up, it would fall out the muffler end when you held it up on end?
Glued well to the outside, and it won't break up. I ended up drilling a bunch of 1/2" holes in it and then using a sawzall to cut out the rest. I just replaced the head pipe with Fuel Moto's and it worked even better. Here's the difference.
Ok lonewolf, so did you cut your pipe yourself and gut it? Then reweld?
This is something I may attempt myself. I do have a wire welder, and I guess if I used clamps to hold it in place to weld it should be fine. Also, what is the worst that can happen if the back half is a smidge off? I can't imagine much.. no attach points on it, right? The muffler hangs off the bracket by the bags,,,,,
There is a guy on Ebay who is selling these too, 79.00 and your pipe in exchange. Seems to be out doing the Fuel Moto price! LOL
