What's that oily smell coming from the A/C?
Old 01-29-2010 | 12:14 AM
fairplay's Avatar
fairplay
Originally Posted by Shovelhead Jack
You learn to love the smell of oil and the feel of it on your skin when you ride a bike that teaches you to enjoy every trouble free minute of riding. You become one helluva wrench and in short fashion.
ah yes, the smell of oil will remind you of sex. so does the smell of hoppes no.9
Old 01-29-2010 | 12:15 AM
ashmarc's Avatar
ashmarc
Twinrider,
From the looks of your last two threads, you might want to consider a thorough service to yer scooter....
Nice little oil, trans & primary change and properly clean that air cleaner.
I would suggest the HD service manual for your specific bike. They are priceless and you can save a ton of $$$ on general repairs & service.
Good luck.
Old 01-29-2010 | 12:16 AM
Shovelhead Jack's Avatar
Shovelhead Jack
You got that right! You remind me that I need to clean some guns for the pure satisfaction of it.
Old 01-29-2010 | 12:19 AM
fairplay's Avatar
fairplay
oops, got the HD forum and the S&W forum mixed up with the sex-a-non forum again. hate it when that happens
Old 01-29-2010 | 12:38 AM
Twinrider's Avatar
Twinrider
Originally Posted by ashmarc
Twinrider,
Good luck.
I've got the manual and do regular oil changes on the bike. But it is my first time using a stage 1 filter so I appreciate the advice.
Old 01-29-2010 | 04:37 AM
JONNIEROCK's Avatar
JONNIEROCK
Twinrider,
I get the same smell, but only when closing the throttle at higher speeds. How about you?
Thanks Jonnierock
Old 01-29-2010 | 04:45 AM
Twinrider's Avatar
Twinrider
Originally Posted by JONNIEROCK
Twinrider,
Thanks Jonnierock
I've been riding the bike for over a year and just noticed the smell for the first time on my commute yesterday sitting at traffic lights. The oil was last changed about 3,000 miles ago so I don't think it's related to having too much oil in the bike. When I took off the AC cover I noticed a little oil in the bottom of it so I'm guessing the air filter is due for a clean.
Old 01-29-2010 | 05:24 AM
todd-67's Avatar
todd-67
The oil laying there is from what others have told you.... It's oil being blown out through the crank case vent line the runs from the crank case and vents off into the air cleaner. The purpose being to take the gasses and run them back into the engine to be burned for emissions... The stage one cleaner being more open than stock is not as efficient scavenging these gasses... that is why you smell it.
Old 01-29-2010 | 05:31 AM
Sandcrab's Avatar
Sandcrab
Default Problem solver
Originally Posted by Twinrider
The last couple rides I noticed an oily smell coming from the stage 1 air cleaner and when I took off the football cover there was a little oil inside on the bottom of it. I know the filter is due for a cleaning.
Would this be the cause of the smell or is there something else I need to check?
The problem is the stage 1 air cleaner and any other upgrades you put on. So to solve the problem, I will swap my OEM parts with your parts and yes, I will put up with the oil and you will not have to.
Old 01-29-2010 | 06:33 AM
No Tyme's Avatar
No Tyme
My question is wouldn't the engine benefit from exhausting this breather tube away from the filter and directly into the air? I think I read earlier that this will increase carbon buildup in the engine. Did I read that correctly?
