Lowering kit that doesn't negatively affect suspension?
SUspensions are systems. I f you change one component it becomes a compromise that affects others. I'd recommend you find a good shop that knows how to evaluate your goals and what you want to accomplish with the mod and then let them recommend a solution. WHen a suspension is designed everything from the tire pressures and sizes, wheel diameters and weights, shock performance and mounting, ride height and rake, front to rear weight ratios, spring rates, and sizes are all put into the equation. Be careful about just adding lowering blocks, or shorter springs or some such. It will affect the bike's dynamic responses and could have a severe impact on bike handling and safety.
The angle of the shocks doesn't change that much. Any method for lowering the rear of the bike will affect maximum lean angle in cornering. Unless the '09s and 10s are different the tire will bottom out against the fender before you reach the maximum travel of the stock shocks.
I'm willing to lose a little ground clearance for a lower seat height. Its a trade off, I know, but the new touring frames have so much clearance to start with that I'm pretty sure it will be OK (won;'t be as bad a s riding a Deluxe!!)
Without using an expensive(but nice) air ride system to jack the bike up when moving no, it will effect the ride. The 2nd best option would be to lower 1 to 1 1/2 inches or less using replacement air shocks, such as the ones used on the FLHX and front springs from Burly, progressive or HD. The 3rd best option would be replacing the air shocks with a shorter spring shock, and the least desirable is the lowering block which angles the stock shocks back. I have this, and it's not really bad, but it's only 1 1/4 inch lower in juat the rear. Gonna do the front 1 inch this winter w/a progressive kit.
60wt
06-15-2009 06:39 PM
