Metal thread tapping question for machinists or anyone
If it's only 1/8 thick it's way to thin to tap. Rule of thumb the minimum depth needs 1-1/2 times the bolt diameter. So a 1/2" bolt needs to be tapped 3/4 inch deep. Machinist/Tool and Die Maker for 37 years. I guarantee it won't hold long in 1/8 thick steel no matter how fine the thread! If clearance for a wrench is a problem look at welding a nut to the back of your bracket and then drilling through the hole. Then you have the strength of the nut and don't need to get a wrench behind the bracket..
indiggio
2014-2023 Touring Models
07-02-2017 12:48 AM
