jiffy stand spring?
Old 01-26-2010 | 12:46 AM
tekeum's Avatar
tekeum
Default jiffy stand spring?
what is the best way to get it back on?
Old 01-26-2010 | 12:49 AM
dawg's Avatar
dawg
Old 01-26-2010 | 06:36 AM
hojones's Avatar
hojones
I use a pair of vise grips on the spring to stretch it onto the stand.
Old 01-26-2010 | 07:03 AM
1flhtk4me's Avatar
1flhtk4me
Same here.
Old 01-26-2010 | 07:46 AM
strtarrow's Avatar
strtarrow
Just curious, did you have a reason to remove it or did something happen?
Old 01-26-2010 | 08:23 AM
BlkSilverado's Avatar
BlkSilverado
Mine got stretched from hitting a speed hump in a parking lot, When i bought the new one the parts guy told me to loosen the mount for the side stand and put the spring on that way. He said stretching it to get it on without loosening the stand could damage the spring.
Old 01-26-2010 | 08:30 AM
xxxflhrci's Avatar
xxxflhrci
Handful of pennies............Bend the spring over and put a pennyor two between each coil. In the end, it will be long enough to fit. Lower the kickstand and the pennies will fall out.
Old 01-26-2010 | 08:55 AM
baldeagle503's Avatar
baldeagle503
AND THAT IS FRIGGIN BRILLIANT!
nice.
Old 01-26-2010 | 09:03 AM
nahanhoku's Avatar
nahanhoku
If the Jiffy Stand is in the UP postition, the spring goes on with less effort. Put the one end ot the spring in the frame first, then pull the other end into the Jiffy stand using a screwdriver in the spring eyelet.
Old 01-26-2010 | 09:09 AM
gmc's Avatar
gmc
Rotate the stand forward and it goes on.
Quick Reply: jiffy stand spring?
