111hp/115ft lbs...should I be disappointed?
Old 06-14-2011, 10:00 AM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
what was the cost for the power increase. 1000 per 10 horses gained, 2000 per 10 horses gained, etc.
  #122
Old 06-14-2011, 10:18 AM
alkrisma's Avatar
alkrisma
alkrisma is offline
sounds pretty dam good to me, I'd be happy
  #123
Old 06-16-2011, 06:59 AM
2009blackpearle's Avatar
2009blackpearle
2009blackpearle is offline
Default not the answer but just curious
when bike was first put together did any one do a cold cranking pressure for a number to watch over the years for wear. cylinder valve bleed down. when I first did my 103 with 255 cams left plugs out, put pressure guage in one plug hole no acr open i got 197 lbs in both cylinders.
this winter I did head change mva's 10.5-1 pistions and got 215lbs on the 103. hope that number isnt too high for my dyno run .
just got 1200 mile on it dyno this weekend.
103 255 cam. comp static should be at 10.1 kept it lower due to 255 camsstock heaD GASKET AT .044 mva heads--power duels, monster rounds, stock intake. was worried the 58mm would be too big and low end would run like crap. I can always add it later, real easy change out.
hoping to hit 105 hp and 112 tq.
cylinder pressure held for 1.5 hours lost about 2 lbs sitting still.
  #124
Old 06-18-2011, 05:30 AM
neverhme's Avatar
neverhme
neverhme is offline
stop staring at the af/r's. Aftermarket cams will need timing tables adjusted to get the most of it.I dont think 110 cvo heads are cut the same as s/e 110 heads.
  #125
Old 06-19-2011, 06:19 PM
2009blackpearle
Default got dyno
well my 103 with mva heads, 10.5-1 pistons, 255 cams, power duels and monster rounds got 98 hp and 107 torque . popped front exhaust gasket out while on dyno.
  #126
Old 06-19-2011, 07:50 PM
Sam07's Avatar
Sam07
Sam07 is offline
depends on the experience of the person doing the tuning. I brought my road king to Carls speedshop in daytona who has a proven history of record breaking speed. Doug, Carls son, took his time to get every bit of power out of my motor. 96 ft/lbs at the wheel on my evo with a thunderheader and i can pick the front end off the ground. Im grin from ear to ear!
JimGnitecki
Engine Mechanical Topics
172
02-05-2015 02:31 PM
ajignats
12-26-2013 11:10 AM
20RoadGlidin
06-16-2012 11:21 AM
Beak
12-17-2010 05:47 PM
22349a
01-18-2010 07:03 AM
Quick Reply: 111hp/115ft lbs...should I be disappointed?
