ISO Grips golf club tape
Old 01-25-2010 | 01:08 PM
Sniper 2712's Avatar
Sniper 2712
6th Gear
Default ISO Grips golf club tape
I put a new pair of ISO grips on my road king classic with the glue supplied. And the left grip did not hold. I read about the golf club tape and will try it. Is one layer of the tape all that is needed or should you wrap it with the tape several times? Thanks
Old 01-25-2010 | 01:12 PM
dawg's Avatar
dawg
Really? I found that every pair of ISO grips I've worked with, the glue was extreme and I can never get the darn things off.
Old 01-25-2010 | 01:14 PM
jimsflh's Avatar
jimsflh
I used gorilla glue on mine, will have to destroy the grip to remove it, but better than worrying about, or experiencing it coming off in a curve.
Old 01-25-2010 | 01:15 PM
Sniper 2712
6th Gear
I had the local harley shop install them and came loose on the first ride. I did a search on the forum and found several others have had the same problem.
Old 01-25-2010 | 01:17 PM
Ronp42's Avatar
Ronp42
Account Retired
I can help you there my friend. I've regriped many golf clubs in my life. had to give it up due to a bad back. The tape comes in two different size's 1" and 2", I would buy the 1" wide and spiral wrap it so it lays flat. one wrap will do it. You can buy the fluid, But I always used lighter fluid. or you can use gasoline. Any solvent will do! Wet the tape good and shove the grip on real fast before it starts setting up. It will do the job!! When I put my grips on, I didn't use the little tube of Crazy glue they send either. Good luck!
Old 01-25-2010 | 01:20 PM
Sniper 2712
6th Gear
Thanks a friend is bringing over the tape (both sizes) and solvent. I will try it with one layer.
Old 01-25-2010 | 01:21 PM
Wassup8687's Avatar
Wassup8687
One layer should work fine.
Old 01-25-2010 | 01:22 PM
PistonPuller's Avatar
PistonPuller
I used electrical tape. A few wraps around the bar made the diameter a little bigger. Then I just sort of screwed the grip on. It held very well. It was good to because I just replaced the handle bars and didn't ruin my grips taking them off
Old 01-25-2010 | 02:09 PM
Copper Hog's Avatar
Copper Hog
Been lucky I guess, never had issue with the provided glue....
Old 01-25-2010 | 02:27 PM
Keithhu's Avatar
Keithhu
I've spoken with 2 local dealerships, they both refuse to install Kuryakyn grips for this very reason. In fact one of the dealerships served as an expert witness in a lawsuit.
Quick Reply: ISO Grips golf club tape
