I don't understand why the HP and Torque curves cross below 5,000 RPM. In every other dyno i've seen they cross over 5,000 RPM. What's going on in this case?
It's because the vertical scaling is not equal on the HP & Torque axis's (sp?) - as Hogdoc already pointed out.
It would be easier to compare this to others if the scaling was set properly and the afr chart were included.
If it rides good and you are happy, then **** on what anyone else thinks....
