I put BUB7 true duals (crossover pipe removed) on my 09' FLHX. I found that the rear pipe hits the left side-panel and required a few beers and some late night garage engineering to make it fit without touching my new paint (I'm not impressed BUB). BUB needs to correct that problem since the 09' and later have larger left side-panels. They are louder pipes than the Rhines, and a whole lot louder than stock. I'm currently looking to put quieter baffles in them so I can hear if I'm pulling away from the sirens behind me.
I think Rinehart did that for the '10 models with the stupid 12mm heated O2 sensors. That way they could have a true dual setup and not need to extend one of the 02 sensor wires. The stock sensors plug in under the "six-speed" cover on the transmission, not at the heads like earlier bikes.
