DEEPER!#@%!
DEEPER!#@%!
I've got Wildpigs. I did the sheetmetal mod to deepen them up a bit and thought I was good to go, until I rode my bud's 2003 FatBoy. He's got V&H Bigshots and man, they sound like a couple of canons going off at idle. Very rich, deep bass sound. I think he only has one or two baffles in.
Aside from going to duals which I fully intend to do....is there anything else that can be done to these WP's to get them deeper or am I looking at something like the T-Rex setup (I know bounty will be in here soon to show those clamp free pipes of his, but seriously wondering FOR NOW if I can get them deeper w/o laying out $600+)
DEFINITELY needs to be deeper (and louder). I saw a post a while back about chopping a section out of the baffle and welding the end caps back together, but I don't know if that would do it.
Thanks in advance,
J
Thanks in advance,
J
RE: DEEPER!#@%!
There is only so much sound you can get out of a set of slip on's. You might try cutting the baffle down a bit. If you go that route, stick a 1/4" bolt through the remaining section to increase the backpressure. If that don't suit you, then your only other option is to get a set of slip on grag pipes until you srping for the big dollar item.
RE: DEEPER!#@%!
If you like the sound of longshots why not put them on yours, see them on ebay all the time for baggers way cheaper(389.00 range i think) thru those dealers than most. And regardless all systems sound different if you like it the best then thats the only way to get that exact sound.
RE: DEEPER!#@%!
ORIGINAL: gunrunner
RE: DEEPER!#@%!
ORIGINAL: jmxp
Thanks in advance,
J
Thanks in advance,
J
RE: DEEPER!#@%!
ORIGINAL: Bryan TTM
it has worked for me several times on several different baffles...if youre gonna buy some duals anyway, experiment and find out
Ramadka
Exhaust System Topics
07-05-2010 12:49 AM
