Oil Temperature Gauge
I just bought an oil temp gauge for my bike. On the advice of several folks on this forum, I decided to wait until it came before going to NAPA and buying the brass adapter that's required to install the sending unit in the oil pan. When I opened the box there was one in there and it was listed on the parts list on the instruction sheet. Also there are two wires on the harness that plugs in to the sending unit. I have two questions: 1. when did they start including the adapter in the kit and 2. since one of the wires on the harness is a ground do I need to worry about using the thread sealer that is recommended in the instructions. I would assume that the ground wire will ground the sending unit regardless of whether you use the thread sealer or not. They recommended Loctite 565 Thread Sealant, which was a pain in the *** to find. I'm waiting for somebody's advice before I tackle the installation. I would appreciate any input. Thanks!!!
The inclusion of the adapter had to be post '06 because I had to buy the Napa fitting. At that time the MoCo had the sensor installed in an oil line. As for the grounding issue, you should be OK with the sealant as long as you use the grounding wire. I wouldn't worry too much because the adapter is a pipe thread which is tappered and designed for better sealing. Good luck with your project.
As a suggestion, while you have the fairing off, it wouldn't be too much work to re-arrange your gauges and put your new oil temp with your oil pressure. I would also recommend putting your oil temp gauge in the top location.
Thread Sealer
First my kit I bought last year included the adapter. I used just a small amount of the thread sealant. I also put mine on the same side as oil pressure. Follow what the paper says and all should be right. Moving the fuel gauge is not a big problem , just slice the tubing a little and pull the wiring back alittle and you will gain a few inches in length and connectors should reach new home OK.
BTW, just ground the sender anywhere on the frame that's handy. Just find an existing small bolt and attach it there, but make sure there is some contact with metal, not just powdercoat.
