Oil Temperature Gauge
Hawg08,
I put mine in last weekend....I just used some teflon tape and it works fine and no leaks. I didn't drain the oil either. I just put the sensor in the adapter first and had it ready when I took the plug out out the pan, quickly put my finger over the hole then took it off and quickly screwed in the adapter/sensor...lost about a tablespoon of oil. :-) As far as the ground, it uses the ground wire from the light bulb wiring from the air temp gauge. (You cut the wires at the air temp gauge and attach them to the oil temp gauge using the included ring terminal cnnectors.)
