Looking into getting a 2010 SG. Just wondering what is out there for exhaust systems? I will probably be doing a SE stage 4 engine on it before I get it. Stay with stock exhaust and change muffler? or is something else available?
I have a 2010 SG and want to do duals. I don't care about changing the head pipes out. I am ok with the cats and o2 sensors. I don't need real loud i just want some sound and I want 2 pipes not 1
I have a 2010 SG as well. I installed the V&H Power Duals, V&H Monster Ovals, Heavy Breather Air Cleaner, and PC V Tuner. I am very pleased with the results, butt dyno says more power, much improved throttle response, deep rumble but not so loud as to drown out the tunes. As an added bonus, the perceived heat on the right side is much less.
I believe to get 2 pipes you need to get 2010 Ultra head pipes because of the o2 sensor size. Then you may need a bracket for the muffler under the left bag. The 2010 SG and RG pipes do not cross under the bike.
I guess my biggest deal is the dealer wants 2K for pipes. The screaming eagle controler is the only one that does not void warranty. The controller is 700.00 and 1000 for pipes plus labour makes it 2K.
If I use the pc or other contrller it knocks out my 5 year warranty...
Sounds like your options are pretty limited if you want to maintain the warrantee.
