ABS BAGGER WITH A SINGLE DISC,Is it possible???
Old 11-22-2010, 11:44 AM
kalkhoff's Avatar
kalkhoff
kalkhoff is offline
Default abs solved.
I was told by the folks at FBI that on an ABS bike they recommend not changing the master cylinder size and that the stock size helps move the fluid involved with the lengthly line used to go from the ABS brain box to the left side caliper especially with a 6 piston. FYI. FBI now makes a part specifically to convert an abs bike to single disk however it is mearly a brake line around 60 inches that runs from the abs box to the caliper. Eliminate the T and you're done. This is on page 78 of the 2010 Fat Baggers Inc book.
Old 11-22-2010, 11:51 AM
DR. V-TWIN's Avatar
DR. V-TWIN
DR. V-TWIN is offline
Former Sponsor
You need a 9/16" bore master cylinder for this conversion as the abs has an 11/16" bore which will not work properly with the single disc setup.
Drew
Old 11-22-2010, 12:30 PM
kalkhoff's Avatar
kalkhoff
kalkhoff is offline
Just got off the phone with FBI again after drag post. This line actually comes from Drag and made into a kit. They say try it and see how it feels and then change it if necessary. They also say that with abs, you're not eliminating a huge amount of brake line. THe lever may stiffen up a tad but should operate and function. I just ordered one 5 minutes ago and am pretty excited about it. Worst case I'll convert to 9/16. They've done a bunch of ABS single disc conversions at many bike shows. They say it works...
Old 01-29-2011, 01:08 PM
leohd's Avatar
leohd
leohd is offline
I purchased the brake line that fbi sells for near $100, decided on a different route, if anybody wants it I'll sell it for $50, never used it.pm me if wanted. SOLD
97badfatboy
08-08-2023 10:45 AM
dowhat
12-19-2017 12:03 PM
tech7734
04-22-2017 10:45 PM
Cornel
07-10-2015 09:59 AM
rscott
01-27-2012 11:53 AM
Quick Reply: ABS BAGGER WITH A SINGLE DISC,Is it possible???
