new wheels on older bagger
you probably would want to change the wheel bearings anyway,so take your old spacer out of the 99 model wheel,put it in between the new 3/4in bearings and put the wheel on.i have an 06 ultra with an older model sportster aluminum wheel that i made work by opening the center up to accept the later model spacer.the diameter of the bearings are the same.just be sure to use the spacers from your wheels.the 06 uses 1in bearings, the only difference is the 99 and 06 bearings is the inside diameter.
