Help-one quick PC3 question?
01-19-2010 | 09:16 PM
Do I have to go through all the PC3 procedures to install another map or can I just down load the other map. Thanks
01-19-2010 | 09:20 PM
Just download the map from the PC3 program on your PC once the PC3 is hooked up on the bike, with the 9 volt battery hooked up or the ignition on. Once you install it will let you know if it was accepted.
01-19-2010 | 11:11 PM
1)Select - get Map, save map file, (in case you want to go back)
2)Open map file and select your map you want.
3)Send map.
Easy with the bike running.......5 minutes tops.
Mark
zobell
08-05-2018 08:30 AM
Surfcitydude
Vance & Hines
04-17-2017 02:37 PM
airjoe
08-05-2016 10:45 PM
wildeano
01-07-2010 03:43 PM
Mr5150
05-06-2007 05:20 PM
