Pinging issue
Pinging issue
Okay had a pinging issue with my HQ107at 3000 - 3100 rpm under load (WOT), was suggested that I get the tuner to remove a few degrees in that range. They removed the timing no w bike does not ping but runs with way less power. The question, If I put old map back in SEST will it adjust the timing back the way it was. I would rather have a little pinging and power vs a dog powered bike. Will get a tune as soon as I ahve time to ride to Texas.
Not sure about the SEST, MB and if you have the ability to adjust the map or not. But with my power commander, I went in and adjusted the timing a couple points. I had similar issue, before and after installing the PC3 USB. The map was adjusted for me by Jamie @ Fuel Moto, to remove a bit of ping at the same range as you. The adjusted map set the timing as -3. I went in (twice) and changed it to -2 and then -1 and got some power back without the ping.
Jerry, you REALLY don't want PING. It can be detrimental to your build, ESPECIALLY if you can hear it, since it's surpassed knock retard where you normally may not hear it.
You have the SEST? Do you have the Smarttune feature? If so, this "may" tune it out with the suggested VE adjustments, but all that could mean is it's throwing fuel at the problem instead of fixing it.........ie, proper timing.
MB, your old map would have all of the previous values, including timing.
Taking 3* of timing out of only the 90-100 kpa -- 3000-3100 rpm cells would not have a dramatic effect on the engine's performance. If the engine is performing differently outside of those cells, more was done to the map than simply changing those cells.
My $.02
Use the SEST logging to measure the conditions under which the ping is occuring - bring up the knock retard front and rear traces and then have a look at the MAP, TP, VE and advance.
If you look at the attached screen capture you can see the computer is pulling out 8 degrees of timing to stop the ping. The rear cyl isnt pinging at all, just the front.
The front and rear are running similar timing, so timing is unlikely to be the problem. When I checked the VE maps the front was lower than the rear in this area.
To fix this I upped the VE around 2750 and the problem is gone. I never touched the timing.
DO NOT pull out timing unless you have tried adding fuel. You will loose torque very rapidly because the engine is running lean AND the timing is retarded.
