Installed Andrews 21N Cams - First Ride
Bike: 2006 Road King, K & N Air Cleaner, Vance & Hines Basic Slip Ons, Power Commander III USB and now Andrews 21N cams.
I’m disappointed as hell! It’s way more vibey at low RPMs and doesn’t seem to be any more powerful at low RPMs, as it is supposed to be, or any RPM for that matter. I think it may just be a fueling problem but won’t be able to get a dyno tune for a few more weeks and want to ride during that time so I have a couple of questions.
My current PC III map worked great with the stock cams and the only change was the cams. I'm thinking that, since the Andrews 21 pulls harder at lower RPMs, it will help to add fuel to my current PC III map in the lower RPM areas for Throttle Positions 5% to 80% or so. The question is now much fuel to add. Any suggestions on this?
Also, if someone has a Power Commander map for a bike configured similarly that they wouldn’t mind sending that would be very helpful.
Thanks for suggestions/help!
Ted – Denver
Email: mapsmc@gmaill.com
Ted – Denver
Give DynoJet a call and tell them your mod's and they will tell you which one of their
"can maps" will get you close until you can get it to a tuner...I did this for my '04 RK and the map they told me to try was pretty damn close...they were actually good people to deal with.
Ted - Denver
Ted - Denver
Here is the link to the maps from DynoJet for your bike.
http://www.powercommander.com/powerc...mdl=31&yr=2006
If you just click on the Downloads at the top of the website you can download the Control Center software needed to upload the map to your bike.
If you have any questions use the "Contact Us" at the top of the website and go to Tech Support. Stan Lass from their Tech department has been absolutely awesome helping me out.
What map did you end up going with? I'm putting the Andrews 21N in my bike right now and would appreciate any info that you learned.
Eric
