Droid cell phone holder for handlebars
#101
#102
For now I took the isolator and cables back and will use the iPod. I have seen a small ground loop isolater that has 3.5mm ends on it online for under 20.00 so might order one in the near future to see if it will work.
#103
Now I have noticed some cracking lately from the auxiliary plugs at the phone end but its a loose connection from the auxiliary plug not seating fully in the plug. I have another cable from rshack that's basic and it does not have this problem. Thinks some auxiliary cable are somewhat loose in the connections to be getting any background noise from the scoot.
#104
Droid noise in stereo gone!
Well the iPod lasted about three days before the skip song button wouldn't work anymore.
Really wanted to use the Droid instead so searched the web more and found a VW forum where they had found a resolution for the issue. What they used was a Griffin Noise-Reducing Audio Cable (http://www.griffintechnology.com/pro...ng-audio-cable).
Returned the iPod and went to Microcenter and picked up the cable for 19.99 plus tax and tried it and it took all of the noise out (the cable can be found online much cheaper but I wanted to try it on a planned trip so picked it up locally). The cable has a small black plastic box about midway through the cable that may be a ground loop isolator, not sure.
I took the outer fairing off and ran the cable through where the handlebars come out of the inner fairing on both sides to hide the extra length (cable is 6' long) and secured the black plastic box with wire ties. I used the Droid for over 500 miles on a road trip to the National Motorcycle Museum and JP Cycles this past weekend for music and navigation with the Verizon charger and it worked perfectly.
I know the root of this problem is supposed to be bad grounds so may go through the connections over the winter but this works great for now!
#107
just a quick update, i have an incredible and i have been using it as my gps and also for music for awhile now and it has worked pretty much flawlessly, i have 2 sets of 3.5 mm plugs one for the xm unit that had previously that was on the master cylinder, and another for the droid which is mounted on the other side, i just swap plugs depending what I am using.
Now the bad part...I wore gloves for the first time this weekend...the screen will not recognize commands with gloves on!!!
oh well
oh well
#108
Not As Nice but...
Here is a holder I found on e-bay. Now its not as nice as the $100+ one...But it gets the jobs done.
http://cgi.ebay.com/MOTORCYCLE-Bike-...item43a6a6d5c8
#109
#110
I have a Droid X, mounted in a RAM mount with the short fingers. The car cradle is not necessary for it to work, and it works great with the included (for free) Google mapping and navigation, which includes satellite mapping. As you ride, what you see on the screen is what you see down the road. It also comes standard with a 32 memory. I prefer using it in the vertical position, as it shows the road ahead farther than in the horizontal position, plus it doesn't block any of my gauges in the vertical position.
The one drawback is that gloved fingers do not work on the touch screen.
Here's where I got the mount.
http://www.mountguys.com/SearchResul...24&Search.y=17
