DYI Tweeter pods after removing fairing mirrors
Old 01-18-2010, 10:30 AM
TRUBRIT's Avatar
TRUBRIT
TRUBRIT is offline
Default DYI Tweeter pods after removing fairing mirrors
Taller bars meant losing the fairing mirrors. Liked the idea of installing Tweeters in their place. Did not like the angle using the surface or flush mount. Got two pieces of 1 1/2" PVC Conduit from Home Depot. Cut at 35 degrees on my Chop saw. Sanded and painted. Glued in place with two part epoxy. Used the Polk Audio flush mount which after a little sanding was a press fit. Just have to run a small bead of caulk around the join and touch up the paint where I was careless. The Tweeters are now aimed at my ears and not at the cars either side.
Attached Thumbnails DYI Tweeter pods after removing fairing mirrors-tweeter-pods-1.jpg   DYI Tweeter pods after removing fairing mirrors-tweeter-pods-2.jpg   DYI Tweeter pods after removing fairing mirrors-tweeter-pods-3.jpg
Old 01-18-2010, 10:36 AM
hog-doc's Avatar
hog-doc
hog-doc is offline
That looks good!
Old 01-18-2010, 10:40 AM
riteway's Avatar
riteway
riteway is offline
Trick!!! :-)
Old 01-18-2010, 10:41 AM
Towboater07's Avatar
Towboater07
Towboater07 is offline
Nice job
Old 01-18-2010, 10:45 AM
leohd's Avatar
leohd
leohd is offline
neatoh
Old 01-18-2010, 10:53 AM
jdreed520's Avatar
jdreed520
jdreed520 is offline
Cool idea...
Old 01-18-2010, 11:04 AM
TRUBRIT's Avatar
TRUBRIT
TRUBRIT is offline
Thank you all. I get so many good ideas from the Forum, my turn to give back.
Old 01-18-2010, 01:02 PM
PadreL's Avatar
PadreL
PadreL is offline
Nice job!
Old 01-18-2010, 01:25 PM
bdp's Avatar
bdp
bdp is offline
Nice work, you should post that in the DIY sticky
Old 01-18-2010, 01:40 PM
Primo's Avatar
Primo
Primo is offline
Very innovative. Kudos to you.
Quick Reply: DYI Tweeter pods after removing fairing mirrors
