Tank Removal Question
The manual outlines a procedure to remove the gas tank. It includes running the motor out of fuel after the fuel pump fuse is removed; the purpose being to eliminate the fuel under pressure. Is that necessary if the bike has been in storage and not run for 2 months? Is there always fuel under pressure no matter how long it has been since the motor was run?
Any advice will be appreciated.
I've done it without doing the fuse thing after the bike has been sitting and it was fine with no pressure. I would suggest getting the fuel line crossover quick connect from Herko and installing it while your tank is being taken off and you won't have to worry about it the next time.
I just siphon out the gas from the tank, then I pinch off the crossover tube, have a 1/4" rubber tube ready to put on the crossover nipple to get the remaining gas out of the tank. Once that is done, remove all the bolts and console, undo the fuel fitting, and the tank comes off with minimal mess if any at all.
No need to mess with fuses or anything at all.
Steve
Steve
I think the fuel pump fuse procedure is recommended to cover those instances when someone decides to take the tank off right after riding. Everyone seems to agree that the pressure in the fuel line dissipates over time.
It was my understanding the cross over fuel line had a rigid center tube that could be damaged if pinched. Not your experience????
cross over line will not be under pressure but the line from the tank to the efi will be, easiest thing to do is just hold a rag up there when you disconnect to catch the little initial squirt of fuel. The cross over line has metal tubes from the tank but they are only an inch or so long. Don't try pinching them too close to the tank.
