Harley Genuine Clear Top Coat Instructions!
Old 01-14-2010 | 09:09 PM
davessworks's Avatar
davessworks
Default Harley Genuine Clear Top Coat Instructions!
Am I missing something here? Just finishing off a rock chip repair and figured I'd read the directions for the Harley Genuine Motorparts "Clear Top Coat".
Directions
1. Shake vigorously for about 2-3 minutes
2. For optimum adhesion sand area to be touched up
3. Close container tightly after each use
4. For best results follow with a clear coat.
Old 01-14-2010 | 09:12 PM
Sancho's Avatar
Sancho
Not missing much. Give about 10 minute flash between coats. Hand rub it out with 3M rubbing compound fine after about 1 week.
Old 01-14-2010 | 09:16 PM
davessworks
But I've been clear coating the clear coat for days now and I don't know when to stop
Old 01-14-2010 | 09:18 PM
1fast2liter's Avatar
1fast2liter
the directions are pretty much all the same unless useing their 3 stage paints... for clear the surface needs to be scuffed up a little. aint mixed to directions then sprayed.. if your a paint guy youll know what to do.... harley paint is the same as ppg...
Old 01-14-2010 | 10:01 PM
skratch's Avatar
skratch
i think what he is trying to point out is that he is using the top coat, but the instructions are telling him to follow up with a top coat......
Old 01-14-2010 | 10:27 PM
BLKBAGGER's Avatar
BLKBAGGER
I think they put the same directions on the clear as is on the base paint.
Old 01-14-2010 | 11:20 PM
davessworks
I think you may be on to something ;-)
WhiteGoldSG
Touring Parts
12-21-2019 07:16 AM
SSTuner
Powdercoat & Paint
07-05-2013 10:05 PM
05 Spring Class
Powdercoat & Paint
01-21-2011 03:36 PM
jousley
06-29-2010 02:17 PM
wsg
General Topics/Tech Tips
01-06-2007 12:59 AM
Quick Reply: Harley Genuine Clear Top Coat Instructions!
