All these cam threads lately...
Old 01-14-2010 | 10:56 PM
dawg's Avatar
dawg
Phil, me hopes you are going to use his 3 stage oil pump, yes? jcbpa here on forum just sprung for one of those on my recommendation.
Old 01-14-2010 | 11:22 PM
iclick's Avatar
iclick
Originally Posted by PhilM
Please don't drag me into another Squeal'n Beagle 255 debate.
My experience, advice, and recommendation is the TR525.
You just drug yourself into the debate by your own volition, Phil...again. I would suggest that a 41° intake close your low-end will suffer with the TR525's when installed in a stock motor. If you dispute this, please explain why.
Old 01-15-2010 | 12:04 AM
iclick's Avatar
iclick
Originally Posted by slick813
Thanks for the advice so far, I have the service manual already. I guess I need to keep an eye out for a deal on some 255s and go from there. I know there is a huge debate about the 255 cams but I think they would fit my riding style pretty good, I ride a lot with the ol lady 2 up, I am to old to be racing or hot rodding around town.
There isn't much debate, really, just some shouts from a few reliable drive-by detractors. The 255's fit a niche and their strengths and weaknesses are well-established. If they fit your riding style they will be a great choice.
Old 01-15-2010 | 07:26 AM
Buddha64's Avatar
Buddha64
You can do it. I just finished mine and it wasn't too hard. I would recommend you get the inner bearing removal/install tool if your going to replace them. Though with only 600 miles on your bike I'm not too sure that's necessary, I'll let real mechanics answer that one. Just take your time and it's not to hard. If you already have the exaust off that's the hardest part of this change.
George.
Old 01-15-2010 | 08:04 AM
smokindave's Avatar
smokindave
Old 01-15-2010 | 08:14 AM
soos's Avatar
soos
Reading cam threads is like listening to running water. If you read enough of them, you are convinced that changing your cams is the thing to do. As for listening to running water, it just makes you wanna pee.
Old 01-15-2010 | 08:20 AM
UltraKla$$ic's Avatar
UltraKla$$ic
Confucious? or Jim?
Old 01-15-2010 | 08:22 AM
PhilM's Avatar
PhilM
Yes sir!
I have one and actually already ran it some. That is a really sweet pump. It does require the crank to have low runout (I don't recall exact #), due to internal tolerances.
Old 01-15-2010 | 08:23 AM
slick813's Avatar
slick813
Should I replace the cam bearings with only 600 miles? For what they cost it is not about the money, is there a better quality aftermarket bearing or are the stock ones OK. I keep reading about these Torrington B168 bearings, are these stock or aftermarket?
Old 01-15-2010 | 08:27 AM
petemac's Avatar
petemac
I guess winter really has set in.......
