Got to buy a compressor
Try this one: $79 http://www.sears.com/shc/s/p_10153_1...5206000P?mv=rr
or this $59: http://www.sears.com/shc/s/p_10153_1...061224x0000002
A small pancake compressor like this one will suit your purposes just fine. http://www.sears.com/shc/s/p_10153_1...ir+Compressors.
The compressor air tank volume determines how long the compressor runs. If you use air for any other projects, I would recommend the largest tank size compressor you can afford or feel like you need. The smaller the air tank, the longer the compressor will run to fill it up.
but, yeah, you should definitely get one bigger than you think you need. i had a little 8 gal one that i got from harbor freight for 89.00 and when it died, i replaced it with a 25 gal from sears on sale for 299.99. this one has enough umph to run some air tools as well......
Tank size determines how much air you can use once the tank is at full pressure before the pump has to come back on.
The CFM (cubic feet per minute) on the pump is determined by the volume of air the pump will produce at a given pressure.
Bigger tanks USUALLY come with bigger pumps, but there can be a large variance in pumps within a given tank size.
That said, you don't need a lot of volume for a bike lift, and most compressors will make the 100psi requirement.
