BR Customs Apes are in for the Deluxe (pics)
Your bars do look a little wider that mine at the base.
Mine are 17 x 34.
17 is height to the peak, from where the grips actually swoop back down about 2.5~3".
34 is from the center of one grip to the center of the other ~ its about 2" from either end.
They are 1.5" diameter & I had the base made 12" wide, to match the width of the Tach/Speedo housing on the RG ~ at the top of the forks (is that confusing enough?).
After seeing FunkyNova's and questioning him about them, that's what I came up with.
BR has a set of directions for sizing them to fit "you" and "your bike" on his website. He's also got some great "how to" videos on there as well.
____________________
Edit: Add pic to compare base width of mine to that of my inspiration.... I know the pic sux, but until I can get the bike out... it iz what it iz.
Phil,
So basically your hand position is at 14" correct? can you post a picture from the front?
looking good bro, thanks
That's FUNNY! The positive side of my motor work putting other things on hold is that I've been able to rework the cave some.... like any good spelunker would!
Mine are 17 x 34.
Mine are 17 x 34.
Here are a couple pics, but without tank, seat, & there rest of the bike in place for reference, it's probably difficult to get a reasonable idea of positioning. Again.... lighting sux & not clean, but WTF...
Level, from front:
Same, but closer:
From front right, same height:
Side:
Little further back: (there's the seat & tank on the top shelf... does that help?)
I know precisely where EVERYTHING is.
I (almost) always answer my PMs! You glossed over one option I threw out there.... hahahaha! That was Bobby Mock.
The answer to the (as of yet) unanswered question is that I had referenced a Dealership (forget the name), but since that reference, my source decided he needed to look elsewhere, so scratch that one.
