Mounting Hardware for a FLHRC tour pak
Hi Guys
I'm riding an '09 RKC. The rear tour pak I picked up will fit but I'm not sure what all the mounting gear I need now. I already have the 4-point docking pieces already mounted. For rear carrier and back rest. I'm just lookng for all the stuff that comes with the tourpack mounting kit. I'd like both the 2 and 1 up set but will probably start with the one up . Our bike show is next week so I'll try to wait until then on the off chance I'll get lucky there.
Timbo
Timbo
There are all kinds of tour packs and most of the hardware is extra. The bracket that mounts on the bottom of your pack and latches to the QD mounts is one part. If you lucked into a completely assembled pack and just need that mounting bracket, I would say you made out. If you need the other hardware you will discover that HD means hunderd dollah for each and every part. Here is the mount that goes on the box http://accessories.harley-davidson.c...s/default.aspx I think it costs $180.00 if I remember correctly.
ShrinerRider
06-10-2013 09:14 PM
