Custom wheel, single side brake, what spacer on the right side?
Hey guys, Im building this 10 FLHX and I installed the 21" Forge Tech Creation 7 wheel on the front... they sent my stock chrome spacers and I dont like the way they look because you can see the bearings and such... so I ordered the P-M tappered spacers and they work perfect on the left side because they fit over the rotor... well on the right side where I removed the brake rotor it has a good 3/16 of an inch gap where the rotor would normally be. Im thinking I need a spacer for a FL softail or something like that but Eastern Performance told me they cant find one.... anybody else go through this?
T T T... I know one of you guys with a single side brake and custom wheels has had to run into this... right?
I wanted to keep the double rotors on my Limited so I switched from the single sided hub to the double. If you can verify that the single sided PM hub will work for you pm me and we can work something out. My buddy was running single sided on his 2011 RG, I'm double rotors on my 2011 Limited, no issues at all. My bike does have ABS, and I do not know if the wheels you have would make a difference, find out and let me know.
