OK. I can believe that, somewhat. My concern would be why would one indicator light show steady on and the other one blink? Or am I worrying too much about little stuff and need to concetrate on ride more? Thanks for you thoughts EdwardK.
Swap the gloves and jacket liner connections and see if the same light keeps pulsing. The light should pulse on low setting but be solid if you turn the **** to high. If the same light keeps pulsing no matter which accessory is attached to it that would indicate a problem with the controller. If it moves with the accessory there may be a problem with the accessory (your gloves). I had a set of Gerbings and the left glove quit working but I can't remember what the controller lights did.
From the Gerbing website: Test operation of Temp-Controller. If controller is hooked up correctly the LED’s will flash on low setting and remain on solid
on highest setting.
