Horn Hookup --- PLEASE HELP
![Cool](https://www.hdforums.com/forum/images/icons/icon6.gif)
I bought this horn and called the company to make sure it's 12 V
http://www.stebel.it/stebel2009/prod...pologia=pickup
I hooked it up, using this diagram:
http://img192.imageshack.us/img192/4394/jan1001.jpg
It's working, but not more than 30% of the sound
Did I do something wrong?
Please help me.
One more thing:
When I hook it up to 24V (2 butteries X 12V) it's works good,
but horn marked 12V...![](http://images.ibsrv.net/ibsrv/res/src:hdforums.com/get/forum/images/smilies/icon_denk.gif)
Thank you all!
Please help me.
One more thing:
Thank you all!
I have the Wolo BadBoy, when I wired it up according to the supplied wiring diagram, the horn always on. I wired up the relay this way (from my car stereo install days, long time ago) and is working fine:
87 to battery
86 from original horn wire
85 to ground
30 to Wolo horn
I don't think this have anything to do with your problem, though.
87 to battery
85 to ground
30 to Wolo horn
I used the single horn wiring harness here for my Stebel.
http://www.easternbeaver.com/Main/Pr...horn_kits.html
When I first installed mine I wrapped some self adhesive foam around the compressor and it blocked the air intake: after I figured out the problem she worked great.
Last service the dealership unhooked the 2 wires for some reason and when the hooked them back up they did it backwards. No problem, after I figured it out.
Also blew a relay in a heavy rainstorm last year and had to replace the relay... make sure all your wires are covered well.
