Touring Bike Wobble
Question. This may seem dumb but I truely dont know. I had an o7 fatboy, built, and had it over 110 solo and once two up passing two slow moving cars. Got there quick because of the build. Now I have a 2010 roadking and have had it to around 80-85. I have not experienced a wobble. But tell me, what is this brace you speak of? Thanks
Lots of braces on the market to make it better but usually at the cost of more vibration. For my 99 I noticed it in the floorboards only. I put a set of Ohlins shocks on and because of the way they are designed they firmed up the back end completely and got rid of the offending vibration to boot.
The Dunlop E3's are the best tires I've ridden on and they really do make a difference. Gone are the grooves and it just rides smoother and tracks straighter.
all I know is that when i got my 07 FLTC it seemed way more squirrely than my 87 FLST ,just figured it was normal ,, but for S & G's bought a throttle up brace ,after install handling difference on off ramps and sweepers was noticeably better, have way more confidence handling twisties than before install
I never experienced the long-sweeper tank-slapper we all fear, but I did find the stock bike very squirrely on rain grooves or in cross winds. Ditched the laced wheels for cast, swapped the stock tires for Metzlers and put on a TWR brace. Suddenly rain grooves are barely perceptible and never a cause for concern. Cross winds are still a problem, but with that big bar mounted fairing, what are you gonna do?
07fatboycustom, not sure if anyone answered you about what exactly a bagger brace is...
Nothing more than a solid link between the engine and frame. Many brands, just google 'bagger brace' and you'll see some good pics.
The newer models, as some one else said, may have 'cured' the problem. Maybe with better rubber. I know the older bikes had a soft rubber, which over time, can become eaven softer just like the handle bar dampers. This is a cause of some serious wobble, which the braces help.
And again as some one else stated, since they make a more solid connection between the frame and engine, that cirumvents the rubber mount vibration dampening. So, you end up with a bit more vibration, mostly felt at the floor boards. Some notice that more than others, and is usually more acceptable than the fear of what can happen due to the wobble.
Always remain aware about the possibilities of unforeseen (strange word ignore spellin plz) road hazards, and be ready to compensate without losin yer cool. I am often reminded just how quickly a brief moment of inattentiveness can become dangerous...
I was a non-beleiver before swapping tires out to try them...and to me, it's the safest "mod" I've done to my bike yet.
