Notices
Hillside Build Numbers
Old 01-10-2010, 03:06 PM
BadPiggy's Avatar
BadPiggy
BadPiggy is offline
Default Specs Added - Hillside Build Numbers
See post #18
Buddy of mine just did a Hillside 107" build.
Numbers turned out to be:
103 HP
118 TQ
He's wondering why his HP number is low.
He's using the Screaming Eagle Stage 1 intake.
Rinehart True Duals.
Just throwing it out there.
Old 01-10-2010, 04:02 PM
lkr0's Avatar
lkr0
lkr0 is offline
not bad numbers for a 107 my HQs 107 is 109 hp 119 Tq with stock head pipe and thunder header slip on's
103 HP
118 TQ
Old 01-10-2010, 04:04 PM
Faast Ed's Avatar
Faast Ed
Faast Ed is offline
103 HP
118 TQ
What cam?
Old 01-10-2010, 04:05 PM
BadPiggy's Avatar
BadPiggy
BadPiggy is offline
Originally Posted by Faast Ed
What cam?
Whatever Hillside provides with their 107" package.
Old 01-10-2010, 04:12 PM
Faast Ed's Avatar
Faast Ed
Faast Ed is offline
I didn't realize he had just one combo. Can't speculate on the question that was asked about the HP number, without knowing the build.
Old 01-10-2010, 04:20 PM
PhilM's Avatar
PhilM
PhilM is offline
Chris ~ without knowing more about the build, it's tuff to guess.
Heck, it could be dyno that is "stingy" and that's just what it is.
If the package was spec'd by Scott, and things were properly assembled, the tune would be a good place to start looking.
What year & model bike, what pipe, what cams, which (stage?) heads, compression, TB, injectors, ...???...
Old 01-10-2010, 05:30 PM
Mike's Avatar
Mike
Mike is offline
Seems within the appropriate range for a 107. It also might dyno at different numbers next month. It also would likely pull different numbers on a different dyno. If the bike is running well, he should enjoy the ride and quit stressing over the dyno sheets. Too many guys get too wrapped up over what numbers their bikes pull.
But I guess Hillside advertises 120/125 with this build, so I would be more than a little curious too.
Old 01-10-2010, 05:49 PM
Mike's Avatar
Mike
Mike is offline
How does the bike run?
Old 01-10-2010, 08:14 PM
02GhostRiderVA's Avatar
02GhostRiderVA
02GhostRiderVA is offline
103 HP
118 TQ
Hard to say without knowing which stage heads, size of throttle body, cams, compression ratio, etc. With that said, I agree the hp seems low, but if your buddy were a stock throttle body...hmmm.
Old 01-10-2010, 09:22 PM
'05Train's Avatar
'05Train
'05Train is offline
Hard to say without knowing the components and the compression. The pipes are probably holding it back some too.
I'd like to see the curves and the afr, but just looking at that horsepower number, it seems low for a 107. Torque ain't bad.
Quick Reply: Hillside Build Numbers
