I need some help removing the stock radio I have the batwing off I see the 4 bolts that hold the radio. how do you get to the rear ones I cant even get my hands in there to get driver on the bolt theres a big bracket in the way
I did look at the sticky but I did not see how they got it out
See if you can cut off an allen wrench. I still gotta do that. I also letting you know the radio comes out toward the front. Pulled mine, as the audio cut out. Apparently vibration causes this. I'm guessing it was the dunlop cupping front tire issue. New tire now.
I just started having an issue with my audio...not cutting entirely out...but the volume decreasing quite a bit. Is that the same issue you had? If so, what turned out to be the fix?
-clutch-
