Way to Make Transmission Oil Drain Less Messy?
Drained my transmission oil last night on the side-stand, like the manual recommends. Didn't think too much about it, but with it leaned over the oil ran down the cross member and ended up leaving a good amount trapped on it. I like things to be clean under there, so I spent quite a bit of time trying to wipe up all the oil off the top of the crossmember. I could probably use the lift to make the motorcycle level so most of it goes straight down, but then the lift would probably get in the way of my drain pan.
Any tips or suggestions for the next time?
Thanks!
Dave
Thanks!
Dave
same problem here with my 09 road glide. I just did the oil changes, mopped up as good as I could, then took the bike down to the quarter car wash, and used the wand underneath, and it cleaned up pretty good. I haven't gotten my lift yet, and like you, hope with the bike straight, the oil will drain straight down and not hit the cross-member.
Thanks!
Dave
Thanks!
Dave
That puts the drain plug on the high side and WILL NOT give you a complete fluid drain!
Dave
Well I have been thinking about making something to help guys that don't have a lift table or jack. Something that slips under the bike and just holds it upright for oil change maintenance. It would be under the frame and not interfere with either drain plug. Does anyone think this has possibilities? When I didn't have a jack or table I would just put a block of wood on the jiffy stand but, it still has to lean to one side. Of course you could also use the center stands available for bikes that mount permanently.
One other possibility would be a catch system (something like a funnel) with a drain line to a pan that would still work with a jack under it.
