Way to Make Transmission Oil Drain Less Messy?
Haven't done a touring since I haven't even brought it home from the dealer yet but I generally just slip a 4x4 under the front of my softtail frame with shims to hold it perfectly upright and solid. Then slip the drain pan in under the tranny and pull the plug. You've just gotta be careful you don't kick the blocking out. Even if you do you don't have to be that quick to catch the bike before it lays down.
Anyway thanks, and FWIW I may switch out the oil anyway. It's only $6 bucks. I'm not sure I like the clunkyness the tranny seems to have now.
2 x 4 under side stand....doesn't bring the bike to 100% vertical but close enough to drain oil/tranny lube. Low profile oil drain pan from Pep Boys. Pour used oil/gear oil back into empty new oil containers and drop off at Pep Boys for recycling...free of charge. No this is not a Pep Boys commercial. Just works for me.
I use a jack to level the bike and get every drop. I postion the jack as best possible to access the drain plug but its tight. I then use use a small funnel to direct the oil into a low profile pan, which happens to be some of my wifes fine serving ware. This approach works well until she catches me doing it!
i dont use the j&s, i use a condor. same principal, drive the bike right in, step off, the bike is held upright. oil changes are a snap, and no jack parts to worry about being in the way. i have never dripped a drop of tranny oil doing it this way.
