Way to Make Transmission Oil Drain Less Messy?
Just to bust on ya, it's syn3....that in and of itself would make me drain it back out and put in some gear lube like Redline, Mobil 1 or Amsoil To answer your question, don't worry about the little bit that got left in there this time.
Well I have been thinking about making something to help guys that don't have a lift table or jack. Something that slips under the bike and just holds it upright for oil change maintenance. It would be under the frame and not interfere with either drain plug. Does anyone think this has possibilities? When I didn't have a jack or table I would just put a block of wood on the jiffy stand but, it still has to lean to one side. Of course you could also use the center stands available for bikes that mount permanently.
One other possibility would be a catch system (something like a funnel) with a drain line to a pan that would still work with a jack under it.
2 x 4 under side stand....doesn't bring the bike to 100% vertical but close enough to drain oil/tranny lube. Low profile oil drain pan from Pep Boys. Pour used oil/gear oil back into empty new oil containers and drop off at Pep Boys for recycling...free of charge. No this is not a Pep Boys commercial. Just works for me.
Doc, I understand what you are saying but, it seems like they would interfere with getting at the drain bolts and limit putting a pan underneath.
OK, OK, lets be politically correct here. HD employee on hiatus.
Nah, not to worry bud, not my style. There is only one snitch that I know of in HDF...
