Relocate LP under taillight?
01-08-2010, 08:26 AM
Quote:
Originally Posted by
steveh326
My solution was to install the turn signal bar from a streetglide onto my roadglide, then use the curved license plate holder from Kuryakyn that mounts under the signal bar. Probably not the cheapest but I love the way it looks.
What seat do you have?
01-08-2010, 12:06 PM
IAMSWUTIAMS
That's the rear-end I'm looking for.
Do you have any illumination on the LP? Cuz the tag window on my taillight will be pointing up.
you can buy a new lens that has the lp light port on the bottom
01-08-2010, 12:16 PM
IAMSWUTIAMS
I can help you resolve this.
I have spare taillight lenses...one without a tag window at all.
PM me if you're interested.
01-08-2010, 01:59 PM
skratch
BadPiggy
Thanks guys, but the LED lights are part of the lens with the Panacea setup. They can't be separated.
01-08-2010, 03:01 PM
IAMSWUTIAMS
yeah, i had replied before i got to your post about having the panacea taillights.....
good luck
01-08-2010, 04:11 PM
IAMSWUTIAMS
this is mine now...........
Getting rid of the cages around your saddlebags would clean up the rear of your bike a bunch.
01-08-2010, 04:19 PM
I got some LP lights with a red light facing out from J&P cycles for $16.00 and attached my LP frame directly to the fender with bolts and rubber washers. Its 2 lights. one lights the plate one is a red light.
01-08-2010, 05:21 PM
I used a plate mount made by LASER STAR out of the Drag Specialties catalog.
It worked well and is not hard to install.
01-08-2010, 05:24 PM
boogaloodude
can't, they see the ground every now and then
01-08-2010, 05:25 PM
jag1886
I wonder if that will work with the big bar that I have.
