detachable tour pac on a 08 ultra classic?
#31
A nice feature for many of the HD accessories is that HD now includes installation instructions on the website. With the p/n UK provided, you can read the installation instructions.
On a tour pak with side marker lights and/or Ultra light bar, the bike's tour pak wiring harness is run inside the tour pak to connect to the tp's wiring harness. This accessory is essentially an extension cord with one end connecting inside the tour to the tp's wiring harnes, then passes through the tp grommet exiting the tour pak where its other end connects to the bike's tp wiring harness.
The description in the catalog says it's for '97-'05 tour paks, but it works on '06 and newer tp's since they have the same electrical connections and wiring for ground/run/brake circuits. It probably is listed for the '05 and older models because '06 and newer EG Classics don't come OEM with side marker lights as the older Classics did.
Carl
Carl
#32
Neil
RDMC
#35
I HOPE part # 70113-08 does have 3 wires in order for it to work on an Ultra. Because the schematic calls for 3 for an Ultra.
I ordered all my connectors today through DragSpecialties at my dealership because it was actually cheaper since Drag offered the Deusch connectors as a whole instead of parting them out through the HD parts bin.
I'll start a thread as soon as I begin the project with all the part #'s and pics.
EDIT: I just read the .pdf and part #70113-08 uses the three way socket so you should be good but it is WAAAAAAAAAAAAAY cheaper to do it yourself with the appropriate connectors and pins.
Rich Pauls
10-26-2010 12:58 AM
