Of course I can't find my service manual, how hard is it to take just the radio out of a 2006 street glide? I'm going to send it in to ironcrosse radio to get it fixed. Piece of crap that it is.
shouldn't be hard...my road glide all it took was removal of the front fairing......couple of screws holding the radio in....should be easy though.............
Pull outer fairing off. Unplug the antenna cable and the harness from the radio. Remove four allen socket head bolts (two each side). Gently pull the radio out. You will feel the rubber gasket around the radio pull out and it is free. You may/will find it a PITA to remove the four bolts. You can get a long ball allen if you don't have one, works better.
