Battery tender connection = lighter socket?
Old 01-03-2010 | 11:08 AM
dawg's Avatar
dawg
Originally Posted by jgreg65
REALLY?? Ok time for a close inspection. Thanks
Not necessarily. Used to be that the dealers commonly installed the pigtails on the PDI's. Then they stopped because the MOCO started using the tenders with the pigtails included like the Drag Specialties one. You may not have one. If you do, it will be a two pole flat connector coming off the right side above your oil filler.
Old 01-03-2010 | 11:42 AM
Harleypingman's Avatar
Harleypingman
My battery tender connector fits snugly behind the starter solenoid; no flopping around when not in use. Just route the battery connections through an available hole interior to the frame rails.
Old 01-03-2010 | 11:50 AM
fathertime's Avatar
fathertime
From: CHILLIWACK B.C CANADA: have a u.s shipping adress
Originally Posted by rsavage
Your 08 should already be wired for a battery tender.
my 08 wasn't, but it only took a few minutes
Old 01-03-2010 | 12:11 PM
rsavage's Avatar
rsavage
That seems odd. I had an 08 Deluxe that I traded in on a 09 EGC both of which were bought new and both were factory equipped with the battery tender pigtail.
Old 01-03-2010 | 12:34 PM
Faast Ed's Avatar
Faast Ed
Those pigtails are added by the Dealer.
I watched them add mine when I went to pick up the bike. It was an "oops we forgot" thing.
Old 01-03-2010 | 04:51 PM
Seaweed's Avatar
Seaweed
This maybe a stupid question and I looked quickly on the Gerbings site first but can you use your Battery Tender pigtail for your Gerbings connection? Plug & play?
Old 01-03-2010 | 07:13 PM
jgreg65's Avatar
jgreg65
Ok YEP I have one!! NICE thanks guys. Yes you can wire your gerbing plug to it. I did on my last scoot
Old 01-03-2010 | 07:57 PM
mphamrick's Avatar
mphamrick
Mine came with the tender and pre wired, but the stealer that I bought it from installs them on all there bikes.
captainron62
Screamin Eagle CVO Models
11-28-2013 08:40 PM
Sandcrab
Electrical/Lighting/Alarm
03-02-2010 10:36 AM
snakeinct
03-01-2009 11:39 AM
baltimorebook
11-14-2007 06:14 PM
boneman
04-23-2007 07:39 PM
Quick Reply: Battery tender connection = lighter socket?
