Quick Review: J&M In-fairing CB Antenna
Great Job
Hey Carl, just want to let you know how great of a job you are doing for us all and how usefull it is.
I've just bought the JM CB, Mod 2003 DU, for my FLHX, unlike you, i'm actually transforming my SG in almost an UC...i know, i could have bought the UC to start with, but then where would have been all the fun to make it on my own?
Anyhow, this to say that i do have a tour pack, removable, and i already have the 2 HD antennas on it, none is actually connected, they are there just to look right.
When i bought the bike it had already an underfairing FM antenna and that's working fine for me, i barely listen to the radio anyhow, mostly IPOD, so...
I then have installed the tail/brake light kit on my tourpack, which is not as easy as it sounds, but anyway, it was looking odd with no antennas and worst with one only, so i got them both and installed them.
Now i got the JM CB and i thought i would have used the HD CB antenna to make it work.
I got all the parts today and the JM antena connector is way different than the HD CB antenna cable one, one is twice as wider than the other.
I've then looked for another solution, and i've seen the JM hidden CB antenna, loof for a review and found yours, which mad efeel really confortable.
I'm pretty sure i'll get it, and let you know how it wll work.
Thanks so much for now.
fedeferr
fedeferr
fedeferr, give J&M a call and see if they have the adapters you need to use the HD antenna cable. I know they're available since my buddy needed to get them to use an SWR meter on the HD CB module and OEM CB cable.
Glad to help and just doing what many others do here and have done in the past.
Post some pics and "how to" on your J&M CB install; it's an excellent product and others would benefit from such a post.
Carl
Carl
J&m cb
thanks so much carl, i wasn't especting such a quick answer, i guess you are online as well just checking the HD world out.
I'll call J&M tomorrow, if they have the adapter i'd prefer, while it sounds like the "real" antenna will work better then the inner fairing one.
I'll defenetely follow up on it on the forum.
thanks again
thanks again
