Stubborn return cable-won't plull out of switch housing
I've done this many, many times but never had this problem.....Maybe you guys have a solution.
I'm dealing wirh a new bike, so it ain't like anything is corroded or damaged.
The problem is I can't jerk the idle/return cable out of the switch housing like I did the throttle cable....I simply won't come out no matter how well lubed or how hard I pull....I even wedged flat screw drivers under it and it still won't release.....I don't care about damage to the switch housing, but I don't want to harm the cable
So short of cutting the housing away, is there a trick when dealing with one like this?
I'm guessing I can recrimp the lock ring back on before I reinsert the cable into the new housing.
Thanks, Hog-Doc!
Yeah you'll need to straighten it and there will be a bur on the cable fitting you'll need to file smooth!
..The clip WAS mangled and cut deep slots in the old cable ferrel....There was no way to pick the old clip ring loose, so I pried it out using two large flat blade screwdrivers and trashed the cable and bought a new one....Wasn't worried about old switch housings, so I trashed them too.
Whiffleboy
07-13-2007 11:49 PM
