installing a GPS
Made a wiring harness with 2 wires off the Aux/acc plug under the seat,10 ga. wire off of batt. post for my amp.Ran them in black vinyl wire loom down the frame,followed clutch cable up into fairing,into a waterproof fuse box(mounted under left side of fairing) I made that powers up my 550 Zumo,a power point mounted on the fairing,used mainly for charging a cell phone and my Scala bluetooth unit that I store in the fairing pouch,and a power supply for a sirius radio unit.Didn't really want any more wires coming out under tank.Can't even see the wire loom cable tied to the clutch cable.
Thanks for all of the responses - I ended up pulling the tank and running the wires to the back - I installed a GDO switch and used the extra orange cable at the light pigtail for that hook up - by the way highly recommend the GDO hard wire transmitter.. I plan on doing a big bore kit this winter so pulling the gas tank should make everything a little more accessible and made the GPS wiring a breeze.
