Garmin 660
I ran 12g. wires, black & red, inside shrink wrap, together.
I soldered a mini-spade fuse holder on the red wire, connected both to the battery.
Ran these in the wire trough under the tank.
Drilled a hole in the side of the fairing cap on my Road Glide.
Connected the wires to this:
http://www.powerletproducts.com/prod...let-socket/280
I purchased the shorter 12" Zumo wire to plug into the Powerlet:
http://www.powerletproducts.com/prod...rlet-cable/265
Just an fyi, if you install with a powered switch, the unit will ask you if you want it to stay on or switch off (default on 20 second timer). I ran power from the spare lead off of the headlight (no intentions of running additional lights) as demonstrated in the instructions.
To the OP either way works, solder the connections and install a fuse.
