Anyone use the Dual Bulb Halogen Headlight Kit?
Thinking about buying the dual bulb halogen headlight kit and wondering if someone who has this light can tell me how they like it. I live in the country and ride on a lot of rural roads and the deer are plentiful. Would rather not spend more money on the HID lights if the dual bulb will provide a little more. Appreciate feedback from anyone who has them on their scoot.
I had the dual bulb kit on my '03 Ultra and it was a big improvement over the stock lights. However, the older style stock lights had fluted lens covers and the light from them was terrible. You could not even tell that the light was on during daylight.
The stock light on my '09 Ultra is better than the dual bulb kit and I would not waste my money on it on a newer model bike. JMHO.
I felt the stock headlight on my 09 wasn't really bad, but a little weak. I installed the dual bulb kit and found a little improvement, especially on high. In retrospect I should have just replaced the 7" headlight assembly with a Hella unit. I've done this in cars, I don't know why I didn't think about doing this to my FLHT? This will work far better than getting any aftermarket bulb. You'll have a razor sharp cut-off on low beam that is wide. High beam is improved too. http://cat.hella.com/hella232/jsp/se...a@PR@002395801
Guys, Check out www.ddmtuning.com. Just installed thier HID 55w high and low headlamp kit. They are on sale for $52 complete! Very good quality and guaranteed for life! Super bright!
Had the twin bulb halogen system on my 07 CVO Ultra, as it came stock.
Lighting was poor on low beam, and not much better on high.
I replaced it with a dual beam HID reflector set-up that I purchased through Kurakyn. It's a little pricey, but the bightness and coverage on both low and high beam is worth it if you do alot of night time riding.
You can do it yourself (low beam stays on when you switch to high beam) with a simple wiring splice on the dimmer switch.
Here's a visual explanation:http://www.thp.yuku.com/topic/122
(scroll down to Headlight Trick, about 1/4 down the page)
