Question to anyone who has installed the HD oil cooler. What size allen key did you have to use to screw in the oil filter threaded adapter. I cant seen to find an allen key to fit right.
Any ideas!
Thanks HiTech
Allen key is a large one..I did a search on the forum and found that the head of a 1/4" bolt was perfect. double nutted the threads and was able to use a socket on it.
It takes a 7/16. I did the bolt with two nuts trick to put it on but when I needed to remove it (leaking oil) that trick did not work. It took a bit of searching but I found one.
I've looked for one of these everywhere (Lowe's, Home Depot, Ace) and couldn't find one. They seemed to have every OD except 7/16". Where did you find yours?
