Critical fasteners - Couple of questions
Looking through the chart in my service manual, they all seem pretty self explanitory except for...
Front & Rear brake Disc Mounting screws - I see the bolts where the calipers attach to the forks, and the smaller pin pads, but I'm not seeing any "screws"
Rear master cylinder mounting nut - I'm assuming this is the nut holding the master cylinder to the frame itself?
Handlebar lower clamp (riser) bolts - ??
Pivot shaft - Locknuts and swingarm bracket bolts ??
Question #2 - Do any of these bolts require the removal of exhaust, bags, seat, battery, etc.? The rear axle cone nut looks like I may be able to get a socket in there, but maybe not
Question #3 - The bolts on the calipers and master cylinder look like they have several sides to them, almost like a jagged edged stopsign. None of them appear to be your normal 6 sided bolts where a normal socket fits on there. What kind of tools will I need for these?
Thanks!!
Thanks!!
Those are the correct ones (screws, bolts eh)
Rear master cylinder mounting nut - I'm assuming this is the nut holding the master cylinder to the frame itself? Yes
Handlebar lower clamp (riser) bolts - ?? The risers are what your handlebar is clamped to
Pivot shaft - Locknuts and swingarm bracket bolts ?? Where the swingarm attaches to the rest of the frame
Question #2 - Do any of these bolts require the removal of exhaust, bags, seat, battery, etc.? The rear axle cone nut looks like I may be able to get a socket in there, but maybe not If you have a wrench like the kastar that will fit without removing the exhaust, if not you will have to drop that side
Question #3 - The bolts on the calipers and master cylinder look like they have several sides to them, almost like a jagged edged stopsign. None of them appear to be your normal 6 sided bolts where a normal socket fits on there. What kind of tools will I need for these?They are called 12point sockets, remember they are mm and not sae
I wouldn't worry about the rear axle nut unless the clip is missing, these very seldom loosen so check to see clip is in and adjusting cams are matched. You can get a couple 12" crecent wrenches on them also for a quick check. An area often overlooked are the allen head bolts that hold the shifter levers on and the one at the trans lever. These appear tight but often just bound up, it's a good idea to take them out and reapply some blue locktight and re-torque them with a socket allen. There was alot of info on shift levers and using helm joints on the shifting rod about a month ago. I replaced my trans. lever allen with a hex bolt so that it can be tightened, you'd be surprised how much more leveraged you can get vs. a long allen wrench. My friends 09 fell off after 12k miles.
Thanks for the info guys! I did have some closed end wrenches that were "12 point". I checked all 3 brake calipers, none of them are Torx, they are all held on with those 12 point bolts.
The shift lever is not on the critical fasteners list, but I will check it later today.
Thanks for the advice guys! I really appreciate it.
